U-Joint greasing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by G.M.H, Sep 30, 2006.
  1. G.M.H
    G.M.H Registered Member
    Oct 6, 2002
    78
    wpg. mb canada
    Does anyone make a u-joint (besides CTM) that is greasable thru all 4 caps? Would it be possible to drill and tap the caps of a spicer joint for grease fittings, or are they too hard? It would seem that this would be the best setup, as it would eliminate the cross drilling, and thus the weakness of a greasable joint.
  2. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    in short the true non greaseables are longer lasting than greaseable.
    the seals on a non keep stuff in and other stuff out.
    the seals on a greasable let stuff out and its alot easyer for crap to get in.
    but yes for true off road with lots of water i might run a greasable , but best be a premium joint.
    these days you cant even get the grease gun head on the zerk to grease them. cause the yokes are in the way. so 90% of lube places dont even bother to grease them.
    i see more bad greaseable joints than true non greaseable ones.
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    There is a fitting that you can buy at the local autozone or auto store that fits on the end of the grease gun. It is very small and pushes the ball in and allows you to grease the u-joint. I believe it was about $10.
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    mine was less than 4 bux, came w/ 2. be careful with those suckers tho...
  5. Can Can
    15,555
    146
    Cochrane, Alberta, Canada
    FWIW, I believe the fittings you're talking about are called recessed grease fittings. I've been running them on my 84 for about 8 years, ever since I upgraded to Moog u-joints in the front end. They work fine......
  6. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    OX u-joints are greasable thru all 4 caps.
