U-Joint help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Blazer, Dec 26, 2000.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    Well I am swapping everything from my 78 in to my 84 when I got to the rear drive shaft it will not bolt up in the 84 cuz the ujoint is to short. The 78 had a 12 bolt the 84 has a 10 bolt. I remember reading something about a odd sized ujoint would this ujoint fix my problem or am I gonna have to switch my axles out to?? If this ujoint will work what exactly is it part #?
    thanks
    Scott
    78blazer
  2. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    Its 1310 (outside clips) to 3r (inside clips) i believe the parts # is a 3-3130 neapco- that's by memory though- give me a ring i'll try to help ya out- jesse 530-872-5725 high angle driveline
  3. 78Blazer
    873
    Michigan
    Thanks for the reply got my ujoint today at napa...
    Scott
    78blazer
