u-joint install/ removal guide needed
Discussion in 'The Garage' started by 5trucks, Feb 21, 2007.
  1. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    There used to be a step by step instruction page on pirate that lance did that had some great pics. Anyone have a guide with pics so i can take out my stock u-joints and replace them with 5-760x joints and full circle clips? Any help would be much appreciated.
  2. gibby2268
    gibby2268 1/2 ton status
    Jun 6, 2006
    553
    Middle TN
  3. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    easiest way to remove is to just torch it then beat the caps out with a ball peen hammer, install works good with a vise, put one cap in one side with the lockin clip and make sure fully seated then put joint in the put other cap in and make sure needles stay in place, then tap cap in and put clip in, farely easy, might have to beat on ears a little to spread them apart to get last clip in good luck
  4. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    my weapon of choice is a reciprocating saw, in the absence of a proper u-joint press. chop the cross and tap the caps out. of course, i'd use the saw to spread butter if it wouldn't offend fellow diners. i love that thing and don't get to use it enough.
  5. 85mudbogger
    Feb 5, 2007
    226
    missouri
