u joint issues on '76 k5....
Discussion in 'The Garage' started by chops76, May 17, 2005.
  1. chops76
    chops76 Registered Member
    May 6, 2005
    38
    south elgin, il
    anybody got words on how to keep a 1976 blazer with only a 6" suspension lift with 35's from chompin' up u - joints???i drive this thing daily and its starting to nickel and dime the sh!t out of me..ha....any soutions... : :D
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You might try adding some 1" spacers beteen the crossmember and frame to lower the rear output of the t-case a bit. I ran mine like this for a long time when it was a dd. One down side to this is that it makes your front driveshaft angle a bit steeper. Not so much a problem on the front though.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Are you angles correct? Get it fixed and drive up here by me and we can do a little wheeling
  4. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    2 things one has already been mentioned by dropping your t-case and also make sure your driveline is balanced if it is not you will burn up u-joints like there is no tomorrow the angles also do matter alot so i would check all of the above.
  5. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    i have a 76 w/6in lift .rear pinion prolly needs to get rotated down.i'm going to get a cv joint in it.should fix it.since its a 76 its prolly full time 4x4 so u don't want a worse front drive line angle by droping the T-case imo
  6. chops76
    May 6, 2005
    38
    south elgin, il
    thanks eveybody for your replies....i already have the 1" spacers for the transfercase plate....how can you check to see if the angle is correct? i am currently in the process of converting the full time np203 to 4x2 with the conversion kit...since the drive shaft will be out , this would problably be the best time to make adjustments...i am also looking into the c.v. jointed drive shafts as well..anybody know where i can pick one up or how much they run???
  7. chops76
    May 6, 2005
    38
    south elgin, il
    thanks for the info...yeah, i dont want to drop the transfercase anymore than it already is...i already have the 1" spacers...i am looking into the c.v. jointed drive shafts as well..know where i can get one or how much they run?
  8. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I have a '90 K5 and just put a 4" lift on a couple of months ago. That thing vibrated like crazy. I hated driving it. Yesterday I got my new shaft with a CV joint and now it drives perfect. No vibration at all. Definitely the route to go.
  9. chops76
    May 6, 2005
    38
    south elgin, il
    hey, where can i get one and about how much did it run ya??thanks man
  10. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Got mine from Rye Valley Oil and Gear in Sugar Grove, VA. I'm from MS and they came highly recommended. Ask for Ronnie. He was a great help. 866-793-6451
  11. chops76
    May 6, 2005
    38
    south elgin, il
    about how much did the drive shaft run??
