U-joint problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Timmer_71, Oct 15, 2002.
  1. Timmer_71
    Timmer_71 Registered Member
    Aug 2, 2002
    15
    Zeeland Michigan
    Just recently my '78 Blazer started to shake/vibrate when I get up to around 50mph+ This only seems to happen after it shifts into 3rd and only when I am on the gas. When I let off it there is no more vibration. I am thinking that this is because one or more of my u-joints are going bad. What I can't seem to figue out is how to determine which one it is? What is a good method to figure this out?
  2. codeman
    codeman Registered Member
    May 8, 2002
    42
    Lincoln, Nebraska
    Just replace both of them. It's cheap and easy.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well you can visually inspect them, then you can unload the weight of them and try wiggling them, if there is movement they're bad.
  4. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I would replace both if I was you. My 91 was doing the same thing and it ended up being the front one. I know b/c it blew and took the slip yoke and the yoke on my D-shaft with it /forums/images/graemlins/eek.gif I changed both on the back after that. So, moral of the story is get it/them fixed, don't keep riding with it.
