U-joint probs/ tapered blocks?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Predator, Nov 3, 2001.
  1. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    Finally got the K5 driving and noticed, I guess, the rear u-joint vibe ("humm" starting at about 30MPH). Installed the TC 4" tapered lift blocks for lift in the rear, shouldn't these help? The short end of the block should be towards the front, right? The pinion angle doesn't look as extreme at the axle as at the case. What next???
    My K5 Buildup: <a target="_blank" href=http://www.geocities.com/gettin_deep>http://www.geocities.com/gettin_deep</a>
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Make sure the two angles are the same. Ultimately, most likely, lowering your transfer case.
    Tim
  3. Predator
    Jun 19, 2001
    130
    OKC,OK
    How far is it safe to lower it? Do I just put spacers between the frame and the support??
  4. Predator
    Jun 19, 2001
    130
    OKC,OK
    Should've done a search for this first....found all I need. [​IMG]
