U-joint question
Discussion in 'The Garage' started by Russell, Jun 28, 2005.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Hey guys!
    I am about to pick up a K15 as a summer driver while I finish my K25 off. Anyways, It needs driveshafts, as the po converted it from a 203 case to a 205 case.
    I've got a rear driveshaft from a 205 -> 14 bolt that I could use, but since the truck is a half ton (I've only ever dealt with 3/4 tons) will the same shaft fit the 12 bolt rear? I'd assume the 14 bolt would have a bigger u-joint, right?
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    14FF uses a bigger joint but you can get a conversion joint to go from the shat to the 1/2 ton yoke
    something else to check is a 14FF has a much longer snout than a 1/2 ton rear axle so the driveshaft may be to short, i don't know for sure as I have not delt with this exact swap
  3. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
    Just did that conversion. The 14b is in fact longer. And the 205 is in fact shorter than the 103. But not quite the same number of inches! So likely any "stock" driveshaft isn't going to fit. I think the stock is going to be a little long. So convert the 14b to 1/2 ton yoke and shorten the shaft. easiest fix? :hack:
  4. Russell
    Jun 23, 2000
    7,925
    337
    Hmm, I guess my best bet is to find a 1980 K10 with an SM465. They all came with 205s (1/2 ton, 3/4 ton, or 1 ton) so one of their driveshafts should work...
