U-joint Question
Discussion in 'The Garage' started by 1970Jimmy, May 31, 2002.
  1. 1970Jimmy
    1970Jimmy Registered Member
    Apr 27, 2002
    75
    Cookeville, TN
    I am about to swap a D44 and 14 bolt from a 3/4T into my 70 Jimmy. Does anyone have the part number for the u-joint I'll need to go from the 3/4T yoke to the 1/2T driveshaft for the 14 bolt?? Also, does the front need a similar u-joint or does the D44 from a 3/4T and a half ton take the same one?
    Thanks a bunch!
  2. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I believe the front will be the same as the 1/2 ton. When I put my 14BFF in place of the broken 12 bolt in my truck I used a Napa part # 348 (conversion joint). The 348 that I used has the outside lock rings. But yours may be different.
