U-Joint Questions
Discussion in 'The Garage' started by andhar, May 14, 2004.
  1. andhar
    andhar 1/2 ton status
    Jan 7, 2004
    138
    Newburgh NY
    I have known that my k5 needed U-Joints for a lil while now , anyway I went to autozone today and go a set of "brute force" joints for it, according to the manafacturer they never need to be lubed and have a 1 year warranty.
    My question is , is anyone running them and I bought four of them, 2 for the main drive shaft and 2 for the shaft on the front.
    Opinions Please.
  2. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    I've ran them in a few different trucks. Never had one go bad yet. We used to hook chains on dry pavement when we were dumb kids and I never broke one. /forums/images/graemlins/whistling.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Those are good u-joints. /forums/images/graemlins/waytogo.gif
  4. andhar
    Jan 7, 2004
    138
    Newburgh NY
    do I need all 4 tho? and is there anything else I might want to change as a preventative measure.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Since there are three in the front shaft you might want to go get another one.
    If you have an 80s truck, with 10 bolts unless your truck is a factory 4 speed:
    1-0153 BF at the front pinion
    2-3011 BF for the C/V, (x 2)
    2-3011 BF for the rear shaft, (x 2)
    '70s truck with 12 bolt rear and C/V front:
    Same as above except the rear shaft, for which you'll need two of 1-0153 BF.
    If you have a non-CV front shaft in your truck, 1-0153 BF will fit every driveshaft location.
    Front axle wheel joints are 1-0297 BF
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if they "never need to be lubed" why is the warrantee only 1 year?
    never = 1 year?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    never = 1 year?
    The warranty from Neapco is a Limited Lifetime. Autozone simply chooses to no longer honor it.
    All Neapco u joints are warrantied for life from the manufacturer.
    Autozone gives you THREE MONTHS on the greasables and 1 year on the non-greasables. Buy a Neapco joint anywhere else and it's limited lifetime.
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    They started doing that last year- however, will still honor anyone who purchased it previously. /forums/images/graemlins/smile.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, I know, I've got a record full of lifetime u joints. /forums/images/graemlins/thumb.gif
    Unfortunately I am missing the two part numbers I really need now as my driveshafts are all 1 and 1 1/2 ton now and I have a D60 in the front so my axle joints are no good anymore either.
  10. andhar
    Jan 7, 2004
    138
    Newburgh NY
    Thanks for the info guys!
  11. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Does this mean 70 to 79 ?
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope. CV front shafts didn't come until the later years. '76 or so I do believe. Never owned a truck that old so I can't say for sure.
  13. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Both my 70 and 71 have spicer style cv up front(yoke type not flange type).
