u-joint recommendations
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mud Bath, Jul 9, 2001.
  1. Mud Bath
    Mud Bath Registered Member
    Aug 28, 2000
    84
    Wake Forest NC
    Just curious what kind of ujoints everyone uses in their axle/spindle. What brand do yall recommend using? Mine sound like there dryer than a popcorn fart so i think it is time to replace them. Are there any that can be greased without removing the axle? thanks for any help
  2. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    Spicer
    MAC
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Yep that is what I am using .
    I have to use a needle tip to grease it.
    my truck's not dirty, it's earth tone paint
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Greasable Spicers here.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    The romor is some of the Spicer, are not up to par !
    Buyer be ware
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, thats because some people go to an 'el cheapo' parts store and get the cheap stuff and then go buy Spicers just to swap the joints into the other box and take the Spicer box back and keep the 'el cheapo' box which has the Spicer joint in it!!!!!!!!!
  7. Executioner
    Feb 22, 2000
    1,530
    I guess you can pull that off, if the people don't know Spicer's !!
    The one's I saw at the driveline shop had Spicer stamped/cast into the u-joint, and were made in china,
    they looks very differnent .
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    spicer are what i run and have had no problems
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  9. Grim-Reaper
    7,385
    Atlanta
    Brute force from auto zone lifetime warranty. Keep spares with me and check them about once a year super good and give them the quick check every trail ride when I clean up looking for spinning a loose nees or missing caps or clips. So far I have never had one fail. and if it does I get the replacement for free. Now almost every spicer on my truck has given it up now. I greased them often and they still failed. The failure was due to dried out seals or plugged greas passages.
    It's not my damn planet monkey boy!
    <A target="_blank" HREF=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</A>
    Grim-Reaper
  10. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Spicer!!
    74 Blazer
    Zepplin
    Check out my Blazer <A target="_blank" HREF=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</A>
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am with you Grim and use Brute Force also. As long as you have most of the joint, they will replace it for free, no questions asked! Cant beat that with a stick!
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
