u joint removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Oct 25, 2002.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    I've run into some difficutly (called my stupidity) in removing the u joints. I have the rear drive shaft off, and have swapped the rear u-joint no problem, but how do you get the front u joint (on the rear driveshaft) out? /forums/images/graemlins/k5.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Look for snap rings on the inside instead of the outside. Good Luck.
  3. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    oops, forgot to say, I already took the snap rings off the inside, but how to you actually knock the old u joint out?
  4. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    You really should get a u-joint tool. It looks like a beefy C-clamp that pushes the bearing retainers out. You can use a large C-clamp and a socket (slightly smaller socket than the retainers) and it will work, but it's a little frustrating to get everything lined up. Harbor Freight has a not-so-costly u-joint tool that works fine. Look at the article "packing for the trail" on this website for a picture of the u-joint tool.
    Be sure to spray it down with some penetrant and let it soak and that will also help. The tool also helps you install the new u-joints.
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I've always done it with a socket and a hammer. I can usually do it in like 15 minutes on my tailgate. Although I've never had to replace the style with the enternal c-clips. I can't imagine it would be much different though. Here's how I do it--Remove the clips. Place a socket on the end of the u-joint cap and pound the u-joint all the way till it won't go any further. Somethimes I get lucky and the opposite cap will fall out. If this doesnt happen, flip the driverline over and knock the u-joint back the other way by hammering on the body of the joint itself, or the part that slips inside the cap. (DONT do ths if you are reusing the u-joint). Eventually this will move the cap far enuff out of the yoke that you can get the u-joint out. When the joint itself comes out, the caps are easy enuf to remove. I don't know if that made any sense......Hopefully ya get the idea. /forums/images/graemlins/confused.gif /forums/images/graemlins/rotfl.gif
  6. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I used a vise and socket.
