U-joint says POP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bherring, May 5, 2002.
  1. bherring
    bherring Registered Member
    Nov 2, 2000
    55
    VA,USA
    With the welded front, I broke my first axleshaft u-joint today...short side. Tires were pretty straight, but I bounced it in some rocks with heavy throttle. I agree.........it was way too easy.
    What's the best way to fit the mangled shafts through the knuckle? Cutting torch? Balljoint removal?
    Also, can you destroy other stuff (besides the other side u-joint) by leaving it in 4wd if the broken side's hub is not locked. I'm talking about the disconnected shafts having too much play.
    Thanks for input. -Beck.
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I would say that a cutting torch is the easiest way to get the mangled parts out. I'm not sure what you mean by the disconnected shafts flopping around. If you just unlock the hub on the broken side, it will be turned by the diff. You will have even more torque go to the remaining side by keeping it locked in. If the inner axle falls out, you will lose your geardope. Also, it could interfere with steering. The only really strong reason I see is the added torque to the other side and bad sounds coming from the broken side.
  3. Grim-Reaper
    7,385
    Atlanta
    If your locked and you bust one it's time to unlock and run in 2wd. Busted up shafts can, have and will cut the nuts off the balljoints and cause the knuckle to come off.
