u joint strap problem
Discussion in 'The Garage' started by big83chevy4x4, Apr 23, 2003.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i bought new straps for the 78 blazer at /forums/images/graemlins/angryfire.gifautozone /forums/images/graemlins/angryfire.gif, when i went to go put them in i noticed that the holes were full of dirt. so i cleaned it out best i could and sprayed wd-40 in the holes to help get rid of most of the dirt in the threads themselfs. when i went to put the bolts in they go in about 1 1/2 turns and is hard to turn so i put a wrench on it /forums/images/graemlins/rolleyes.gif and it seems like it gets harder. so i pull the bolt out and it looked like it was begining to strip them out. i put one of the other bolts in it and it is like it is suppose to turn until the same point. QUESTION what is the correct thread for the bolt? im thinking about getting a tap to run through the holes to clean them out. could they had given me the wrong ones? it a 12 bolt rear end.
    i wanted to drive it today but looks like maybe tomorrow
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    If i remember right they should be 5/16" Fine Thread.
  3. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    my bet is the bolts are metric.
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they look like standard because they have 6 lines on the head like a grade 8 bolt. im going to pic up a tap tommorow and make it fit /forums/images/graemlins/thumb.gif
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    a coulpe of years ago I bought some straps too, got the parts at Autozone/HI-LO Orilly/Advance/Chief, can't remeber
    but they did not fit, went to Napa or Car Quest
    got the right straps and bolts to fit the first time.
    All of them do not reproduce the strap like the OEM
    go to GM for the strap, last time I got them
    they were reasonable.
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i got them to work i jest bought a tap and cleaned the threads out.
    now if i only can get it to run on 7+ year old gas /forums/images/graemlins/ignore.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/1zhelp.gif
  7. Executioner
    Feb 22, 2000
    1,530
    Good glad it worked out.
    Are you going anywhere this weekend ?
    I am get itchy to find MUD, or some trails !
