u-joint - strap vrs. bolt
Discussion in 'The Garage' started by four_by_ken, Dec 2, 2004.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Can someone shed some insight to me on the benefits of one over the other.
    The yokes are differant, correct? Can't picture how, but I believe they are.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The u-bolt is the better method , its holds the cap better and EVENLY . The yoke is different in that its machined for the nuts to fit on there flat and the u-bolt to go through . I still run straps myself , only because I'm a working stiff and have bills /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  3. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    True that the straps 'hold' more of the joint though?
    /forums/images/graemlins/dunno.gif
  4. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    Yoke with the straps have a finite amount of clamping force on the u-joint cap. If the strap or yoke develops wear then it may no longer effectively do it's job. The u-bolt can compensate for this wear. The u-bolt down side is that you can over torque it and deform the cap or crush the needle bearings.
