U-joint tech..pictures
Discussion in 'The Garage' started by Zeus33rd, Jan 20, 2006.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    (Right click, view image in Firefox)
    From left to right- 1310, 1330, 1350, 1410, 1480-
    From left to right- 1310/1330, 1350/1410, 1480-
    1480-
    :eek1:
    1480 is also the same size as a D60 axle joint.
  2. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    nice
  3. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    Can you verify the measurements in this chart and add specs for the s44?
  4. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Something to add...
    This is not verified, just info I've collected.
    U-joint specs and part numbers
    U-joint Series\Width (in)\Cap Dia (in)\Max Angle\Cont Rating (lb-ft)\ Short Duration Rating
    1310............... 3.219....... 1.062........... 30............... 130....................... 800
    1330............... 3.625....... 1.062........... 20............... 150....................... 890
    1350............... 3.625....... 1.188........... 20............... 210....................... 1240
    1410............... 4.188....... 1.188........... 37............... 250.........................?
    1480............... 4.188....... 1.375........... ?................. ?............................?
    S44(3RL)......... 3.655....... 1.125........... ?................. ?.............................?
    U-joint measurements (closest with tape measure)
    Outside of bearing cap to outside of bearing cap X bearing cap diameter
    1310.......... 3 7/32" x 1 1/16"
    1330.......... 3 5/8" x 1 1/16"
    1350.......... 3 5/8" x 1 3/16"
    1410.......... 4 3/16" x 1 3/16"
    1480.......... 4 3/16" x 1 3/8"
    S44(3RL)..... 3 21/32" x 1 1/8"
    Spicer Life Series Universal Joint Cross-Over Index
    Series ========= Kit Part #
    1310 ========== SPL22-1X
    1310/Ford 1-1/8" = SPL22-3X
    1310/7260 ====== SPL22-4X
    1330 ========== SPL25-1X
    1330/Ford 1-1/8" = SPL25-3X
    1330/S44 ======= SPL25-4X
    S44/S44 ======== SPL25-6X
    1330/7290 ====== SPL25-7X
    7290/7290 ====== SPL25-9X
    1350 =========== SPL30-1X
    1410 =========== SPL36-1X
    The Saginaw 44 (S44) joint is also known as the GM 3RL.
    This u-joint uses 'inside' locks.
    The 447 is a 1350/S44 adaptor joint, NOT a 1350/1330.
    73-87 trucks never came with a 1330, it's an S44.
    1330/1350 joint is Neapco PN 2-3050.
    1310/1350 joint is Neapco PN 3-3140.
    S44/1350 joint is Neapco PN 2-1153.
  5. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    U-Joint Identification Guide
  6. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    eh ..... hmm ...... nice ..... whoa ...... *me explode*
  7. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    we shure got some great info and tech dudes o this site
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    You forgot about 3R...
    Can somebody put this in the tech article thread though? I'd hate for it to get lost. Could save an awful lot of posts about U-Joints.
  9. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Thanks guys, I needed that. Good post! :thumb:
  10. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Do you mean the GM 3RL?
    It's the same joint as the S44.
    Anybody know the actual width of the S44?
    Anybody know the specs on the 1480?
  11. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I don't know the specs on the 1480, but it's the same as a D60 wheel joint. Spicer part# 5-806X.
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The specs for a 1480 are
    Cross width= freakin huge
    Cap diameter= really big:D .
    I dont really know anything at all this is good info though.
    Ira
  13. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well I can tell you that a 3R joint has the width of a 1350 u-joint. The bearing cap is directly between the 1310/1330 and 1350 sizes though. I believe that 1310/1330 are 1 1/16 and the 1350 is 1 3/16, leaving 3R at 1 1/8. :whistle: 1310 is 3 3/16 wide, and 1330/1350/3R are all 3 5/8 wide. So if S44 is the same as 3R...
  14. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    1350/1410 cap is 1-3/16" AFAIK. ;)
  15. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
  16. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Good info, Muddog.
    I measured the S44 tonite and updated the tables with info.
  17. sbyarlay
    sbyarlay Registered Member
    Nov 8, 2005
    63
    Johnstown, CO
    Really helpful thread. Thanks.
  18. TerryD
    TerryD 1/2 ton status Premium Member
    Jul 27, 2008
    3,488
    105
    Covington, Va
    Holy dead thread
    This seems like the most helpful place to put this question and possibly someone later on will find it also.
    OK, so I was searching, and Googling, and any other-ing I can to find info on the 3R / S44 u-joint. I ground up the strap bolts on my 12b the last time out and I'm wanting to go with a u-bolt style pinion yoke.
    As listed above, the 1330 and 1350 have max op angles of 20*. I was wondering if anyone had found what the max op angle of a 3R / S44 is. Does anyone know how to calculate this? Is it as simple as pulling my rear shaft and pushing the yoke around till it will not move any more and measuring the angle?
  19. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
