U-joint
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DumontsK5, Aug 24, 2006.
  1. DumontsK5
    DumontsK5 Registered Member
    Jul 26, 2006
    59
    williamsburg, VA
    I am doing an axle swap from a 10 bolt to a 14bff and i need a 1310/1350 u joint! can you buy them like that if so can i get heavy duty ones and where?
    If not do i have to buy a 1310 and a 1350 and switch 2 caps on each?
  2. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Napa u-joint conversion mark
    (1330)10b -(1350)14b = #447
    (1310)12b-(1350)14b= #348
    search for conversion ujoint.
  3. DumontsK5
    Jul 26, 2006
    59
    williamsburg, VA
    i thought a 10b was a 1310 am i wrong ?
  4. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
  5. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    If the original joint has internal snap rings then it is a Saginaw S44, if it has external snap rings then it's a 1310.
    1310-1350= 3-3140 Car Quest
    Saginaw S44-1350= 2-1153 Car Quest
    Hybrid joints aren't very strong, the best way to go is have the driveshaft redone to accept the correct joint and you just as well put 1350s on both ends while your spending money.
