U-joint #
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Sep 29, 2001.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Whats the item number on the rear U-joint for a stock 84 k-5 10bolt np 208? I will take any info for any store seems that the last u-joint I purchased was too small because the cap moves along with the u-joint within the sleeves which are tightened to the max
    What? You think the hole is too deep? Lemme see...
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  2. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    It should be a 3147.
    chevrules...always has and always will
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've only got Napa numbers here, but the standard is a 534G, and the super strength is a 235. About $12 for the 534G, and $22 for the 235.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. chevrules
    Aug 26, 2001
    127
    Canada
    The 3147 is a spicer number,hope this helps.
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i have had TRW replacements that plain dont fit. they arent even the size listed in their literature.
    buy real dana or spicer. spicer have better seals
    inside snap rings 5-3147x
    outside snap rings 5-178x
