u-joint ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Philly87, Jan 29, 2002.
  1. Philly87
    Philly87 1/2 ton status
    Jul 14, 2000
    465
    6
    El Paso, TX
    Which do you guys prefer, u-joints with or without grease zerks? It seems like the zerks would be a weak point wouldn't it? Thanks for your opinions.
    Philip
  2. MR.GADGET
    MR.GADGET Registered Member
    Jan 9, 2002
    33
    Raleigh NC
    U-joints with zerks will sometimes let go before the gears, drive shafts,and axles do so that you can fix a u-joint in less time then a axle shaft or getting a new drive shaft. If you want zerks you can get better u-joints(stronger) with them but not from the local auto store mail order or on the web... My 2c
    IF IT'S NOT AS BIG AS YOU ARE DRIVE OVER IT!!!!!!!!!!
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    When you use u-joints with zerks it also matters how you install them. You need to install them so that the area with the hole for the zerk is in compression. The cast Iron that they are made from is stronger in compression than tension.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
