U joints Q
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by R72K5, Mar 4, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what size U joints would be in a half ton with 4 speed and 12 bolt and strap type U joints on rear yoke ? whats biggest that can go on the shaft/yokes ?
    4150 smallest or biggest ? i forgot now
    if i go to NAP and say 4150 will they know what im talking about ?
    thanks
  2. ECNiz
    ECNiz Registered Member
    Sep 9, 2000
    54
    Santa Cruz, CA
    I believe the sm465/12bolt uses a 1310 u-joint. If you want
    to go any bigger, you need to change the yokes on the transfercase/driveshaft/12 bolt. Some of the common
    sizes are 1310, 1330, 1350, 1410. 1350 is a 1 ton u-joint
    and 1410 is a 1 1/2 ton u-joint.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    but how can i get any bigger yoke for the 12 bolt ? i may just swap to a 4.10 full floater dana60 if i can go get it soon
    thanks !
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can get a bigger yoke for your 12B at any driveline shop. If you are going to go w/ a 1ton driveshaft you could just use a conversion u-joint till you get your D60 (I would and have went w/ a 14b over a D60). It would be a NAPA#348 if you don't get it at the driveline shop.
