U-Joints sizes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SF87K5, Jul 18, 2003.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    I just got a stock 85 K5 with a 350/TH700r4/NP208. It still has stock 10 B axles. I have a 14 B FF I would like to put init. The 14 B is hooked up to a NP203 that is in a 79 K5.
    Here is my question is the U-joint for a NP203 the same as a NP208?
    I would liek to know if I need to find a new rear drive shaft or if I can use the sameone I already got?
    Thanks for your help. /forums/images/graemlins/thumb.gif
  2. SF87K5
    Oct 27, 2002
    1,105
    Know one can help. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  3. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    is the 208 a slip yoke?
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    the u-joint doesn't change with the transfer case. it changes with the axle. the 14 bolt will have a bigger u-joint. there is a hybrid u-joint to go from a 10 bolt to 14 bolt. the part # is 447 this is a NAPA number.
  5. SF87K5
    Oct 27, 2002
    1,105
    Dan,
    Ok I am having a dumb moment. I cant remember what a slip youke looks like.If you get a pic post one are send it to me as a pm ok.
    Rick I was woudnering about the tcase yoke is all. I have the drive shaft for the 14B also.
  6. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    wellthe 208 uses a slip yoke . your 203 uses a slip shaft.
  7. SF87K5
    Oct 27, 2002
    1,105
    Well I have to bolt the U-joint onto the NP203 useing the bands just like when I bolt it to the axle.
    Let me post the pic of my 203 yoke.
  8. SF87K5
    Oct 27, 2002
    1,105
    This is what my 203's yoke looks like.
    Does the drive shaft bolt to a np208 the same way?
