U-joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Apr 11, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    How bad do they get before they break? I have a new driveshaft and joints, with less than 3000 miles, adn Im starting to get some grinding type vibes as soon as I let off the gas at higher RPM's. I thought my driveline angles were close enough based on what I feel in the cab. But looks like I was wrong. My new rear pinion seal is trickling and like I said above now I have this vide.
    However, when I do the old manual test, getting up under the truck and grabbing the driveshaft, there is no play in the joints that I can feel.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  2. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    what your feeling is called gear rattle - it happends when your angles are excessive or not equal- mailny on lifted rigs-
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I've got a 5 degree shim in the rear and the T-case is lowered with the stock spacers and I have additional washers in with the spacers. I cant lower the T-case any more. The front driveshaft is rubbing the exhaust collector. What's the next step? Move the perches?? OR get a slip yoke eliminator and get the CV shaft?
  4. drivelineman
    Aug 23, 2000
    707
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    NO Thank You... I'll be calling you back.
