"U" joints
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by shooter, May 24, 2001.
  1. shooter
    shooter Registered Member
    May 24, 2001
    18
    Colorado,USA
    \"U\" joints
    This question is minor but i need some advice, i have the front axles out and the ujoints are in good shape. I am thinking of installing a set of new ujoints with grease fittings so i can lube them without taking everything apart. I was told that this is not a good idea. What do you think???
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: \"U\" joints
    That is correct. The steering Ujoints should be the non serviceable type or sealed type. that way the zerk fitting is not in the way at full turn + the sealed version last longer than the servicable type due to the elements not getting into the Ujoint.
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. shooter
    May 24, 2001
    18
    Colorado,USA
    Re: \"U\" joints
    Thank you and i will take your advice.
