U-joints
Discussion in 'The Garage' started by BlitzK5, Oct 9, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Do 10 bolts and dana 44's use the same u-joints. Whats the strongest 10 bolt u-joint you can get. I herd CTM or Yukon were making them for the 10 bolt but all they show on there websites are for dana 44's. Will they work on a 10 bolt?
  2. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    Yes they are the same, I use Ox joints, they are fully rebuildable.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes they are the same ujoint. a ctm will work in a 10 bolt.
  4. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    AFAIK the 297 series is the biggest U-joint you can use in a D44/10b shaft. Based on everything I have seen, CTMs are the best wheelin joints ever made. Ox's are cool, but some people have reported problems on pirate with them coming apart on them... usually the joint body itself is fine, but the screw in arm parts and/or shaft ears are toast.
    The Jantz joint is a good alternative if you don't drive your rig much on the street... it has no bushings at all inside its caps. This, naturally, increases friction but it also allows for much larger "arms" on the joint. The D44 Jantz joint, for instance, has larger arms than a stock D60 joint does. The D60 ones are over in inch across. Thats some serious beef. Randys/Yukon are in the process of mass producing the Jantz joint. The D44 ones are already available. Think they just call it "The Super Joint". They are 4340 and use a gold-colored titanium finish is decrease friction/wear due to the lack of bushings. Apparently they don't currently cryo them... but if you want to go with the Jantz joint, you might want to send them off to have them cryo'd yourself.. will probably make them last longer. Jantz himself owns a rig that runs 44" TSLs, so I can only assume these joints have been tested quite a bit. He's some sort of aerospace engineer if I remember right.
    j
  5. BlitzK5
    Jul 29, 2005
    288
    Is anyone making some 37-38 tires on a 10 bolt survive using these type of joints + upgraded shafts.
  6. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    10 bolt can handle 37s or 38s... in the long run you'll prolly break even the expensive bling upgrade parts though. I'd rather have a D60 with some cheap 4340 yukon shafts/joints than a 10 bolt with bling $pendy CTMs and CTM shafts. Said D60 would be the cheaper axle probably...
    j
  7. BlitzK5
    Jul 29, 2005
    288
    My thoughts to
  8. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I changed my yokes and run big, meaty Spicers. No problems here.
