U-joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solid454, May 23, 2000.
  1. solid454
    solid454 Registered Member
    May 4, 2000
    31
    CA, USA
    Whats the quickest and easiest way to change u-joints?
    BIG HEAVY AND MEAN
  2. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    Quickest?A press or a big enough vise to fit everything into.
    Easiest?Pay somebody else to do it.(where are you?I work cheap,hehehe)
    <font color=red>Wanna'keep wheelin? Get involved!
    Check the "Land Use" section of this board.</font color=red>
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    What I do is use an old socket and 4lb sledgehammer.
    support the shaft, remove the clips, put a bigg socket on the bottom side of the ujoint(bigg enough to allow the cap to fit inside it)put the old socket that is just a bit smaller than the cap on the opposite side and bang, bang, bang the cap should drop into the bigg socket now just work the other side out. Or just pay some one to doit who has all the right tools! Good luck
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
  4. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I second that...That is how I do it.. Just beat on it... I have gotten pretty good at it only takes me a couple of mins..
  5. 72junker
    72junker Registered Member
    Apr 23, 2000
    66
    atlanta (body) colorado (soul)
    I've used Burt's method with a vise instead of a sledge.
