U-joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, Dec 5, 2001.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Does the 3/4t dana 44 use the same u-joints as a 10 bolt front, and what about a 3/4 ton 14 bolt FF use the same as 10 bolt rear?
    Houston, TX
  2. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    This is correct to my knowledge:
    all 1/2ton and 3/4ton front 10 bolts have the same size axle u-joints, which is a 297x, and is the same as "2nd gen" Dana 44's (1/2 and 3/4) which started 77'ish.
    Most rear 10 bolts use a 1310 series joint, although some (my old one included) used 1350's. The 14bolt FF uses a 1350 input.
