u joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88thunder, Aug 16, 2000.
  1. 88thunder
    88thunder Registered Member
    Aug 16, 2000
    9
    Before i bought my 88 k5 the people used it to pull a horse trailor, it now has 125,000 miles on it. i was wondering if i should consider changing the u joints? also there is a little shake every so often around 75 mph, what could that be? any help would be appreciated
    email Crysler12@yahoo.com
  2. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    It probably wouldn't hurt to change them. They are pretty cheap and it's not a hard job to do.
    Canuck
    Go Wide or Stay @ Home
  3. GMC4by4
    GMC4by4 Registered Member
    May 10, 2000
    48
    Silver Spring, MD
    I agree, they are cheap and easy to do, and it couldn't hurt to change them if there's some looseness, but also check your tires for balance. U-joint problems usually begin to manifest themselves at lower speeds than 75mph.
    -Rick
  4. derek2002
    derek2002 1/2 ton status
    Aug 1, 2000
    247
    Midland, Michigan USA
    I get confused about this sometimes... Would this be the u-joints on the driveshaft or the u-joints in the front end? Just always mixed up by that one...
    Later,
    -Derek
    1977 3/4 Ton & Blazer Project (Body Needed)
    http://www.4chevy.com
  5. Your rear drive shaft unless your in four wheel drive when its vibrating.
    IF IT AINT BIG IT AINT BAD!!!!!!
