u joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85GMCJimmy, Sep 23, 2000.
  1. 85GMCJimmy
    85GMCJimmy Registered Member
    Feb 21, 2000
    83
    South Carolina
    My jimmy is using up u joints like they are going out of style for some reason, if i get it fixed it will have been my third set within a year. I have a stock jimmy, with 31's on it, with a 10 bolt rear end..
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    well either you keep putting them in wrong OR you have a severe driveline angle problem! do you have lift,or any kinda' drop motor and tranny mounts?
    DRIVE IT LIKE YOU STOLE IT
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Maybe the driveshaft is out of balance.
    '73 K5
    Chevy good...Ford bad
  4. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    With 31's, you can't have too much lift. Stock or maybe 2". How bad can the driveline angles be?
    I wonder what kind of condition the driveshafts are in? IF they are way out of balance or the slipshaft is loose, it wears the ujoints out quickly.
    -- Mike
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    What brand are you using? Try getting Spicer greaseables and grease them often. Maybe that will help.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  7. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    are you pre greasing? and you might have a dad yoke - loose holes etc- jess
  8. 85GMCJimmy
    Feb 21, 2000
    83
    South Carolina
    on my jimmy i have no lift on mine, do you think when they replaced them one of the drive line angles got out of wack any
  9. drivelineman
    Aug 23, 2000
    707
    no i don't. maybe a spinning cap in your shaft though-
  10. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Maybe tightening straps too much.
  11. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Is she viberating pretty good at or around 55?? Sounds like from what you stated about no lift and 31's, no angle issues apply. I would just get and new drivshaft and new u-joints.
