u-joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by the hulk, Dec 21, 2003.
  1. the hulk
    the hulk Registered Member
    Feb 9, 2003
    40
    phx az
    Well I keep burning up u-joints. I have a 6 inch lift and I had the stock drive line lengthen to fit .Does the 6 inch lift put to much angle on the u-joints
    web page
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    depends on the angles you are running them at! Have you measured? From what I have heard, anything over 15 degrees is bad. Mine are at about 12-13 degrees and I have had no problems yet.
    You could always go with a CV type rear drive shaft.
    Try www.highangledriveline.com
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Are you running blocks in the rear. Having a manual tranny ads a lot of wrap to the springs and really pisses off a u-joint. Check the angle(copared to the ground) of the axle, t-case, driveshaft. I do change my rear DS u-joints about every oil change (2500 miles).
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Maybe, you're not installing them correctly?? That was my problem. I made sure the caps in the yoke were as far outboard as they would go, but completely forgot about making sure the caps under the u-bolts were adjusted outward. I was overheating them every WEEK! Then I asked about it here. I was talking about it to the guy at the driveline shop the other day and he said people have a tendency to overtighten the nuts on the u-bolts. 15-20 foot-pounds is plenty . You want to tighten the nuts until the lock washer collapses all the way, then go about 1/2 turn more. /forums/images/graemlins/thumb.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah and smack your yoke with a hammer before you install it. Sometimes it binds up and it'll put a lot of force on the u joints.
