u jont with wax seal???
Discussion in 'The Garage' started by wraenking, Jan 29, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    help guys
    14 bolt swap. i got the u joint conversion, part number 348 i think, wi=hich is not right anywaya, but the clips wont fit into the driveshaft yoke because the old on had a wax seal
    what can i do????
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    which yoke are you talking about? Slipyoke driveshaft? The yoke at the axle or the slipyoke?
    If the axles are going in an 86 you should need #447 Napa joint not the #348.
    The clips should fit. They fit in my 85 driveshafts just fine.
    Harley
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's not wax, it's plastic injected into the yoke. Melt it out with a torch, propane or oxy acetelyne will melt it out. Do it slowly and heat the yoke as evenly as possible and the joint will come out.
    You need Napa P/N 447 or Neapco 2-1153 to hook up your new to you 14 bolt.
  4. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    I tought on that style you had to use the clips that go under the yoke- c clip looking ones -not the ones you squeeze and stick on top of the cap in the yoke. coud be wrong
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The stock shaft from my truck (700R4 driveshaft) uses the S44 joints and does use the little c-clips on the inside. The other driveshaft in my truck (SM465 driveshaft) uses the 1350 joints and uses the outside style ones you have to squeeze together to get in.
    Harley
