u-jt question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaptCrunch, May 28, 2001.
  1. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    One thing I noticed just now that when I went to measure for my new driveshaft... I have the smaller sized yoke on the 12B I put in the rear.. well it is smaller then the u-jt in the 10B I took out. I know Napa has the adapter u-jt for the 14B, do they make on for this setup too? I would guess it is weaker the 10B jt that was in there... I can switch the yokes no prob, but would like to get it to the shop and on a hoist... taking that sucker off on the ground would be a huge PIA.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    yes there is a crossover joint(bastard-joint i call em)[​IMG]but i dont know the #.just bring both old joints w/ you to the parts store and tell em what the deal is.(it needs to go from a k5 w/ 10 bolt to ?w/ a 12 bolt)then compare the caps before you leave!
    PURE INSANITY
    86 blazer see it at:<A target="_blank" HREF=http://www.zing.com/album/pictures.html?id=4292792569>http://www.zing.com/album/pictures.html?id=4292792569</A>
  3. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    I'd say it is about a 1/2" shorter in u-jt width. I just got the old yoke off on my 10B using my impact. So I might as well try to take the yoke off the 12B too... it must be like pre 73 or whenever the change was I guess... I better check the front one too, but that has the later style u-jt's in the axles and later model spindle and bearings.
    -Mikey
