UAV pouser shots
Discussion in 'The Garage' started by CK5, Apr 15, 2002.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
  3. CK5
    May 19, 1999
    21,623
    701
    CO
    Thank's dude
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Pic 1 looks like the UAV is giving a big smile for the camera. On a side note Steve, with the way the front is trimmed do you think 38.5's will clear at full stuff?
  5. CK5
    May 19, 1999
    21,623
    701
    CO
    Well, I plan on stuffing 39.5's but I will need to "trim" some more of the front for sure, maybe even a little more off the rear.
  6. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Well, if my yours is anything like mine, you will need to tub the rear and either move the front axle forward, or do some serious floor pan mods. I think when I go one ton and to 38's or 40's I will do some serious floor pan mods.
    Depdog
  7. CK5
    May 19, 1999
    21,623
    701
    CO
    Yeah, I plan on doing floorboard mods at that time, I don't think I will need to tub the rear just cut a little more sheet metal, I run spacers in the rear.
  8. Grim-Reaper
    7,385
    Atlanta
    I moved my axle forward and one inch body. I'm clearing 35's that are TRUE 35's without cutting the inner fender. I mean the innerfender is in factory stock location still bolted to the fender lip. Well I think I am. At the Reaper proving grounds (ditch in my yard) It looks like it will work. I need to back it up a ramp and get it nose down with weight on the suspension and double check for sure. I could have gone 1.5 inches forward but I didn't think I have enough drag link to pull that much off. When I do the cross over I can get that extra 1/2 inch.
    I bet you could clear 38's without getting into the floor if you go the 1.5 inches forward. That's on 10 inch rims with a 4 inch back space. You start getting into 14.5 wide tires...ehhhh doubt you can do it without more lift or hacking the floor pan.
  9. Depdog
    1,657
    Georgia
    Well, I am running 36x14.5x15's now and in the rear under full stuff you can hear the inner fender BONG when it gets the inside of the fender well. On the front I am going to have to do some hacking I think. Probaby in the rear too when I go one ton and at least 38's.
    Grim how did the moving the axle forward work out? I was thinking of possibly doing that myself.
    Depdog
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I moved mine 2" forward. As long as you have cross over, it's a sinch. No problems so far. Had to cut the core support to clear the 42s, but I expected that. Added 3" to my front drive shaft to account for the axle move and the 4" lift. I'm very pleased with the results.
  11. CK5
    May 19, 1999
    21,623
    701
    CO
    What back spacing are you running?
  12. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    I know that Keith and I both have 14.50 SX's, but i have a 14 bolt, and he has told me in the past that his tires rub in the rear on the inside. mine have never hit ( ORD shackle flip, extended shackles, stock springs w/ overload NOT cut or flipped), but his ass end may be a little flexier, however i think it may be the fact that the 14 bolt is wider.
    i have seen Deps rig, and can tell you, his rear springs are VERY flexy.
    rob
  13. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Right now with the 35x14.50's on 4 1/8" backspacing wheels and no spacers in the rear they just about touch the inner well when stuffed. The front clears by just a bit. I am planning to move the front axle forward 1" and adding 3/4" of lift to help clear the 38's. On the rear I am going to move the axle back 1 1/2" but in order to pass inspection I am only allowed a 1/4" spacer.
  14. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I think I'll put a rock like that in my garage. Make it easy to change my oil. Could probably sit on a chair and do it....
    Jim
  15. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Hey steve,
    Aren't you the same guy that was talking about being tired of people with a tire up on a rock or something and snapping a picture???
    Just wondering,
    Corey
  16. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    it's a hole lot better than taking a pic of a rig sitting in the dang driveway. nice poser pic steve /forums/images/icons/smile.gif
  17. CK5
    May 19, 1999
    21,623
    701
    CO
    Haha, I just got busted. /forums/images/icons/smile.gif/forums/images/icons/smile.gif
    I meant more of a rock in the middle of nowear as opposed to one on the trail but yeah this was pretty close, good call. I can't get away with anything around here.
  18. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Cool pics.......what MALL is that? /forums/images/icons/laugh.gif
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    This was worth bringing TTT to show what drew me here :thumb:
  20. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    wow pauly, talk about grave digging LOL :thumb:
