UD1 front bumper, Stinger and hidden winch!
Discussion in 'Vendor Forum' started by cybrfire, Feb 8, 2007.
  1. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    some of you guys wanted to see on with these options, here ya go.
    This was built with a Warn HS 9500 inside. It's tucked in there pretty good.
    The entire center section of the bumper is 1/4 plate. Using the HS 9500 we clocked the clutch 2 bolt postions. It's a simple operation, pull the bolts turn it and bolt it back on.
    Let me know what ya think and if you have any questions, fire away!
  2. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    OH, and I forgot to mention, there is to be some more bracing on the stinger yet. Just wanted to get a photo up tonight.
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I love everything you make! Looks Great.
  4. FUBAR
    FUBAR Newbie
    Dec 27, 2006
    CALIFORNIA
    What gauge metal? whats retail on it?
  5. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    They will hit the website at $540 as seen here.
    The center section is all .25" Out side the frame is .188". The sides are also reinforced back to the frame similarly to the way the factory bracketry is.
  6. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Just had a thought! How about your screen name burnt into the bumper, or the trucks name? Any number of custom options for little to no difference in pricing. Holes in the front of the bumper for a recessed light mounting.
    Another option could be, in place of the winch mount, a tool box? Just kickin some ideas around here. If you have some ideas of your own fire away!
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Put a different angle of pic up there Kert. The bumper looks WAY better in person than that pic makes it look.
  8. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I need to shove it outside for better lighting as well. Maybe I'll get that far today!
  9. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  10. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    Is it an option to set it a couple inches higher to cover bodylift gap?
    That thing looks killer.
  11. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Wow kert, another thing to add to my list of parts to buy. Can this be mounted with your B-52s in the forward position?
  12. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    yep, that sure is doable. We can raise it or widen it upward at the drop of a hat!
  13. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I think the two gel. Let me double check that to be sure though.
  14. tomford
    tomford 1/2 ton status Premium Member
    Jan 19, 2006
    921
    7
    New Hampshire
    hey do you have pics of it with the winch in? would a warn xd9000i fit in it and would you make the bumper with out the stinger?
    tom ford
  15. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    The XD9000i won't fit with it the way it is pictured. We can adjust to fit. It's the large chunk of the winch that goes from one side to the other over the top that interferes. Yep, we can do it without the stinger tube.
  16. tomford
    Jan 19, 2006
    921
    7
    New Hampshire
    How much would it be without the stinger and able to fit a warn xd9000i shipped to 01876?
    thanks
    tom ford
  17. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Your looking at $515 neighborhood adjusted to fit that winch and no stinger. front will have to come out so your approach angle is gona take a hit. Not to much can be done about that.
    Need an exact address to calc shipping. Business address can save you as much as $100 in some cases.
  18. tomford
    Jan 19, 2006
    921
    7
    New Hampshire
    i sent you a pm
    tom ford
  19. 75k10chevy
    75k10chevy Registered Member
    Oct 7, 2005
    39
    Liberty Lake, Washington
    Would It be possible to mount a Warn 12k lb. winch in there?
  20. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    The profile of the bumper would change slightly. The bottom would come down and the face would come out to make room. Not a big difference but its there.
