UGH! What size is this fitting!!
Discussion in 'The Garage' started by eclipse, Feb 12, 2007.
  1. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    Ok so I swapped the 10bolt front in my 85 K10 for one with 4.10s, got it all in, the only thing I need is the fitting that goes on top of the diff for the vent tube. The one on my old 10bolt is broke and won't come out. I dont know what size or where to get that damn little fitting. Its the last thing I have left tell I can sell the truck :confused::confused::confused:
  2. goldwing2000
    goldwing2000 Guest
    It's not a threaded fitting. It's pressed in. I drilled out the pressed-in deal and threaded the hole for 1/4" NPT then installed a 45° brass elbow.
  3. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Just tapped mine when it fell out. Be careful with shavings falling into axle tubes. Metal shavings, gears and bearings don't mix well.
