Uh-Oh 2002 Taco Tech...
Discussion in 'The Garage' started by readymix, Jan 29, 2006.
  1. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Alright, Hopefully someone around here can answer these questions.
    I was supposed to go wheeling with my brother-in-law yesterday but his 02 Tacoma was acting like the CV were binding a lot. Problem is that I just finished changing them the other day.
    So we removed the coil-overs and put the CV at zero anlge and tried it agian....on jack stands....Still binding hard. I loked at it from a Solid axle point of view and figured it was the ring gear.
    After opening it up we found that he was missing 3 teeth off of the ring gear.:eek1: Also found out that he has 4.30:1 gears, which are supposedly only available from Toyota for around $700 per ring and pinion set:eek1:
    If that is true we will be re-gearing both ends with 4.56's and a locker of sorts in the rear. Already have tru-trac for the front that I will install.
    Here are the questions....for those of you in the know here.
    • Pinion uses crush sleeve or shims for pre-load?
    • Carrier uses shims or typical 3rd member type pre-load/backlash adjustments
    • Do you have to completly assemble the front IFS chink just to run the pattern?
    I think the BL/carrier pre-load uses spanners like the 14FF and 9" as I think that is what I saw. Not sure os I only looked for a minute.
    Sorry for the non-GM tech, but it has to be done on the cheap and I have regeared almost every kind of solid axle, just never anything IFS.......YET:D
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Damn and I though this was a food question:doah: . Sorry I dont know anything about Toyotas but I can lend a hand if need be just gotta check with the boss:o . I know on my Bros 4runner his has the spanner style adjustment on both his axles. Dunno about pinion pre-load.
    Ira
  3. readymix
    May 30, 2004
    6,706
    26
    I know htre rear has the spaner type as it is a drop out 3rd...IE timkin type.
    The front I am not too sure about.
    I'll try to get pics up later
  4. readymix
    May 30, 2004
    6,706
    26
