Uh oh, can someone help me?
Discussion in 'The Lounge' started by Capman2k, Oct 1, 2006.
  1. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    I got a new (to me) TV and I'm trying to hook it up to my stereo... The only problem is the TV only has audio INPUT, and no OUTPUT :doah:I have an RF Modulator with audio OUTPUTS. I thought that could help me out, but still no worky :confused: :confused:
    Is there a person who can help me?
  2. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    If you are using a cable/sat box hook into there. If using ant only way I know of is to open tv "RISKY TUBE FLYBACKS SHOCK HAZARD" and wire in some speaker connections.
  3. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    You got a DVD/VCR with yellow/white RCA jacks on the back? If you do, I might be able to help you solve this problem.
  4. Capman2k
    Jun 22, 2001
    5,070
    dg
    I was just thinking about it, and I'm not quite sure how I can work it out... I don't have a DVD/VCR, and no cable box either... I think I may just be screwed unless I ditch the PS2 for a real DVD player :doah:
  5. Inu-Hanyou1776
    Oct 1, 2005
    1,345
    Murphy, NC
    Crap, yeah you may be right. You know what I was going to suggest with the RCA jacks right? Is that what kind of audio input jacks the TV has? Might just be able to come up with something.
  6. Capman2k
    Jun 22, 2001
    5,070
    dg
    I have the red, white, and yellow jacks on the back of the TV, and the same on the back of the stereo, both are input jacks...
  7. Inu-Hanyou1776
    Oct 1, 2005
    1,345
    Murphy, NC
    Alright then, now we're getting somewhere. What about the cable that's bringing the signal in? Is it a COAX cable or you have the Red, White, and Yellow RCA plugs that are bringing the signal in?
  8. Capman2k
    Jun 22, 2001
    5,070
    dg
    That would be a COAX sir
  9. Inu-Hanyou1776
    Oct 1, 2005
    1,345
    Murphy, NC
    And that's why you got the RF Modulator. Okay then, you need to get yourself a couple of these guys:
    RCA "Y" Cables. This is one that uses the male plug side all the way, but you can get them with the jack side too. You'll take two of these, plug the single end into the audio outs on the RF Modulator, then take the ends of both and plug one side of both of them into the TV, and the other into the stereo, of course you might need some extensions too. These cables should all be easily available at Radio Shack or somewhere similar.
