Uh oh.. hub leakage!
Discussion in 'The Garage' started by Pookster, Oct 21, 2002.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    So I drove all the way down to uwharrie national park in NC... but after a day of wheeling , I noticed leakage out of one of my front hubs. I know this aint normal... whats going on???
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    leakage, how so? You had grease coming out, is that what you mean?
  3. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    It aint grease. Its diff fluid.
  4. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    ummm, I'm confused /forums/images/graemlins/confused.gif, how is it that you have diff fluid leaking out of your front hubs? As I understand it, the hubs are independant from the rest of the axle. Is it leaking around the knuckles where the axle shaft u-joint is? You should see leakage there if diff fluid is leaking. Unless you are running a closed knuckle axle or something different than stock.
  5. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Its probally a axle seal.
    Colin
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I dont know. But now that you mention it, the hubs should be independent of the axle.. *scratches head*
    Guess I shoulda used a finger and smelled it. /forums/images/graemlins/rotfl.gif
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Assuming that you have internal style locking hubs, remove the outer section of the locking hub and see if the C-clip is still installed on the end of the axle shaft. If that's broken or missing, it will let the hub body move slightly outwards. Then wheel bearing grease can leak out between the locking hub and the wheel hub. There should also be an O-ring on the locking hub where it fits into the wheel hub. If that O-ring is damaged, it can cause leaks also. Look carefully for any water in the wheel bearing grease while you have it apart. If you find any, you'll need to clean out and repack the hubs. Leaving water in there for very long will result in etched bearings and races, which will then fail. /forums/images/graemlins/mad.gif
