uh-oh service engine light
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by downtime2nite, Feb 14, 2003.
  1. downtime2nite
    downtime2nite Registered Member
    Jan 13, 2002
    20
    washington state
    well, started the burbon up this morning and I immeadiatly knew sumpthin was wrong. she didnt go into fast idle mode, I looked down and the "service engine soon" /forums/images/graemlins/angryfire.gif light was staying on. drove very poorly{limp home mode} went a few blocks and it was already warming up, way too soon,pulled over and yup, the headers were glowing. anybody have any ideas where to start? any help appreciated, thanks
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Start by "asking" the ECM whats wrong. Theres a plug on the bottom of your dash, that's the data link connector. Turn the key to the run position with the engine off and jump Terminals A and B in this picture
    http://community.webshots.com/image5/3/49/21/60834921oQTvGs_ph.jpg
    Count how many times your check engine light flashes before the pause and after it. At first you will get code 12 (flash once, pause, flash twice) this code will flash 3 times. This means the computer is in diagnostic mode. Any other codes will flash after that. Once you know what codes are stored in the ECM, post back here to see what to do next
  3. downtime2nite
    Jan 13, 2002
    20
    washington state
    got a code 42, I do believe its just the ignition module, at least Ihope it is!
  4. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    I had the same problem but it wasnt the ignition module it was the ECM /forums/images/graemlins/angryfire.gif.good luck /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
