uh oh... tranny fluid in tcase...
Discussion in 'The Garage' started by jekbrown, Jan 21, 2004.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    since my 205 always dribbles a little bit I was checking the level today... pulled the pinkey out of the case and the fluid was slightly redish. Now I've never had a problem with this before... but for almost a month I had the front end jacked way up on blocks while I messed with relocating my front axle. Is it possible that the seals or whatever between my tcase and tranny are fine and that it was only a problem because I had the rig popping a wheelie for a month or am I gonna have to pull the case and crap? input appreciated...
    j
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You could piss in a 205 and it still wouldn't break. GM even spec'ed the red stuff in the later years. Just ignore it and quit your whining. /forums/images/graemlins/rotfl.gif Your K5 is on the rag. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    lol, I'd be more worried about my tranny being out of fluid and going BOOM than the 205 going belly up. /forums/images/graemlins/wink.gif trannys aint cheap! anyway, still looking for an answer to the main question. Would it be normal for tranny fluid to seep into the tcase if the front end was jacket up higher than the rear for a significant amount of time?
    j
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'd be more worried about gear oil getting into the tranny.
    That will definatly make the trans go boom. Get the rear trans seal fixed.
    That is why most x-fer cases mated to an auto tranny run ATF.
