uh oh!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by walrus101, Apr 29, 2000.
  1. walrus101
    walrus101 Registered Member
    Apr 9, 2000
    91
    texas
    this morning i had to go to a meeting , and when i was leaving it happened. it didn't want to start. it did not even turn over. after about three tries it started right up. it smoked all the way home. after i arrived i checked the smoke - grey. i checked the oil (recent change about a week ago). it was a cream coler. this just happened today; nothing leading up to this. grey smoke is probaly the rings, right? and the cream oil is water in the engine, right? the only way water could have gotten into the engine is from the radiator. i have not driven in rain or water. i don't know where to start i need input, please!!! this is my driver; my wife doesn't know about this yet.
    walrus101
    goo goo gaju
  2. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    Sounds like a blown head gasket. Water gets in there from the water jackets in the heads. A fun job, but not fatal!
    Blazin' in Flagstaff
  3. walrus101
    Apr 9, 2000
    91
    texas
    would this account for the grey smoke?
    walrus101
    goo goo gaju
  4. BillR
    Mar 15, 2000
    164
    Flagstaff, AZ
    Water in the oil or combustion chamber usually puts out a whitish smoke, but gray is not unusual. Try not to drive much further with it. Your lubrication has been reduced with the water in there.
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>This happened to me last month and it turned out to be an intake manifold gasket. i had all the same symptoms exept the smoke</font color=blue>
  6. walrus101
    Apr 9, 2000
    91
    texas
    thanks guys, i am on my way to get the gaskets. now if anyone wants to put them in for me, i am open.
    hehehe.
    thanks again
    walrus101
    goo goo gaju
  7. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    If you want to bring it to Ohio , I would be glad to help...
    <font color=green>[​IMG]Eagle86K5[​IMG]
  8. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    Head gaskets is not THAT hard to change. The downer is you will have to take the intake manifold off....(*thinking*) and the exhaust manifolds too. More gaskets are needed, so to speak (intake & exhaust). The head bolts can be a b*tch to get loose. Do 50 pushups for 3 weeks before you have a go at it[​IMG]
    Andreas
    406cui of pure sh*t[​IMG]
  9. BamaGal
    BamaGal Registered Member
    Mar 15, 2000
    8
    Phenix City AL
    Yep. Same thing, same symptoms, my husband just pulled the engine in my 88 Blazer and replaced all the gaskets two weeks ago. It was a blown head gasket, thank goodness not a cracked block.
    Make sure you clean every thing. I spent the day cleaning rocker arms and lifters in solvent as my husband handed them to me. (Hey - it's my Blazer, I should help where I can!) He took off the oil pan too and cleaned the oil/water out of there.
    She's running better than when we bought her, but in the process we discovered at some point in her past she had thrown a rod, and the valves on one side had been replaced... why only one side we don't know.
    Good Luck!
    SF
