Uhhhh Power Steering Lines?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Resurrection_Joe, Apr 7, 2004.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Man I aplogize for my amazingly random posting of questions....
    Anyway
    I have a 78 truck.... I think.... with a 78 or so engine, I think
    What I KNOW is, I have a 85 2wd sterring box
    I went to a parts store 50 miles away and asked for fittings
    I assumed I could just buy the box ends and hose clamp them on
    Parts store guy sats, "NONONONONONONONONONO"
    So do I need some fancy custom lines or are the two types of lines the same on the pump end and different on the box end?
    Can someone like WTO or TYR or HGG make me some custom lines?
    Thanks for the suffering of myself
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Why not just get a newer pump? It would be less hassle and probably less money in the end.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I think he's probably saying that a hose clamp wont hold up to the pressure of the system. The pressure line is metal coming out of the box, then goes to rubber (I dont know the name of the crimp that is done) but it is crimped around the rubber in 2 full revolutions on my line.
  4. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    I live in the country (farmland) and the local NAPA fabs pressure hoses (hydraulic), try them or a heavy equipment (bobcat-backhoe) rental/repair shop, Tractor Supply, or junkyard (from vehicle w/hoses still connected). The fab shop may require your "old" fittings though.
  5. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yunit - I'd have to buy a new bump and lines, I assume this would cost more than just two new lines, maybe not, the parts guy suggested it too
    gm4x - The parts guy also had a section where they made lines, but they said becasue of liability they wouldnt BASTARDS! Heh
    Thanks for the help so far everyone
    I think my pressured line is the one I didn'y hack apart when taking it apart. I twisted the hose clamp line end to bits
  6. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    they have the ability to make hoses, but refuse to because of liability? Hmmmmm /forums/images/graemlins/doah.gif. Might send someone else in with your hose, but don't tell 'em it's for an automotive power steering unit? Tell 'em it's fer yer John Deere /forums/images/graemlins/waytogo.gif
  7. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    The shop is 50 miles away and I have no firends...
    Ooooh maybe the John Deere shop here in town....
  8. dyeager535
    26,977
    Good luck finding someone that can make them. In the entire Seattle area I could find mention of ONE person, and from talking to him, it sounded very expensive.
    Go find a newer pump, take the fitting out of the back of it (where the pressure line threads in) and swap it with the one on your old pump.
  9. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Anyone know what a new pump runs? Possibly the cost of both lines?
  10. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I looked it up, thanks guys!
  11. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    At the NAPA I work out we make hydraulic hoses. The only thing we will not make are brake line. PS hoses we make all the time.
    Chris
  12. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I just told someone last week to do this same thing. Funny how easy we can forget such an easy solution sometimes.
  13. dyeager535
    26,977
    So what you would do is take the "ends" (fittings) that he would need, say early on one end, late on the other, cut them off of whatever you have as a donor, and crimp them to a rubber hose?
    Not a bad option, but in this case I'd just swap the fitting on the pump. No offense, it just has to be cheaper as long as you can get your hands on another power steering pump.
  14. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Older power steering systems used flare fittings and newer ones use Oring fittings. I'm not sure about the exact years, though. On the return side, you can use transmission hose and hose clamps. On the pressure side, you can either replace the fittting on the back of the pump with one that has the style fitting to match your box, or you can cut the metal line part of the pressure hose and use a compression fitting to attach a different end. For example, if you have 2 pressure hoses, one with Oring fittings and one with flare fittings: cut the metal line (with a tubing cutter like you use on copper pipe) about 2" past the fitting. Then do the same to the coresponding end of the other hose. Use the compression fitting to attach whichever end you need.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If the line can be flared I think that would be much better than trying a compression fitting.
    81 and older is SAE flare fittings
    82 and newer is metric o ring fittings
  16. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Uhhhh Tim, not to sound rude here, but I think you may be wrong about somehting or I may have an anomalous steering box here
    I checked with Brent and it is an 85 2wd box
    (the chunks of hoses that came with it have O rings)
    I'm fairly sure mine is an 78 4wd box
    (the truck has flare fittings)
    The problem with you comes in that when I read your post, I went all willy nilly and thought I had threaded a standard fitting into a metric hole.
    So I run outside in my underwear and cape and start turning the line wrenches
    Turns out, the one hose that didnt get damaged, (the original 78 pressure line) had threaded into the 85 box fine, the only difference was that the box was O ring type and the line flare type
    The end I bought for the non pressure hose that I cut and clamped was the same as the 78 non pressure hose that I mangled in every way, and threaded in fine
    So the thing is, I don't think they're metric, on mine anyway
    So my question is, can I just buy myself a new pressure hose and pop it on? I think the chunk brent left in the box is big enough to use for the non pressure line, or I could just get anew one of those
    Anywone have a clue what Im rambling about?
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    1. I'm absolutely certain that I have a 1982 box on my truck with metric o ring type fittings. If it has an O ring, it's metric.
    2. You can tell the fittings apart in the box by sticking your finger through the pressure line's hole. You can feel the spot where the o ring is going to fit. That's how I knew I had the wrong box (it was an '81 box) on my truck.
    My best suggestion is that you clearly identify what you're working with, because there's no way that there was an SAE flared box on a 1985 truck as far as I know. Not stock to the truck anyway.
    You can always try swapping sector shafts, you know.
  18. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I went to the local Ace today and tried shoving the fitting that came in the 85 2WD box into random things, and what it finally threaded into was 3/8ths hydralic fittings, so aparently, thats what one of the lines is, I realize the other is a bit smaller
    Anyway I am thinking about swapping the shafts, but dear god what a paint hat box was to get on the first time, plus the box is new
    I think I'll just end up buying a new pump and lines from a 1985 C10
    Thanks for the help
    Oh
    The fitting from my 78 took some standard line wrench, the fitting from my 85 box took 18mm (well that was the only thing that fit in a quick check, some standard may fit) but they were both 3/8ths pipe thread
    I was trying to finagle my way into making some power steering lines out of the hydrailic hoses they had at the store, could I just use those with some thread sealer?
  19. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    One more easy/cheep solution would be to swap the reservoirs. That that's where the fittings are, so you just need a reservoir that matches your box, then the proper pressure hose from the parts store. The return side can be hose clamped, just like they did from the factory on my '73.
  20. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    nope, the fitting is in the pump, through the res.
