Uhmw
Discussion in 'The Garage' started by otisringle, Aug 11, 2006.
  1. otisringle
    otisringle 1/2 ton status
    Aug 2, 2005
    148
    california
    where did you get it and how thick??? If someone wants to send a link on where they got it and the thickness of it thatd be great...thank you
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Are you referring to Ultra-High Molecular Weight (UHMW) Polyethylene sheeting? If so, I believe Grainger or McMaster-Carr both sell it (and fortunately, they both have web sites).
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Did we miss something? What the hell are you talking about. :confused:
  4. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Tough, slippery plastic.
  5. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    If he's thinking of the same stuff I mentioned, we used to call it "poor man's teflon". It's a cloudy white stiff plastic that is machinable, has no known solvents (at room temperature that is), and is slick like teflon (but not quite as slick as teflon). It also has a lower max service temp than teflon, but it's a hell of a lot cheaper if it fits your application.
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You talking about delrin plastic?
  7. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    Delrin is a brand name for Acetal, which is also a slippery tough plastic. They are talking about UHMW Ultra High Molecular Weight Poly Ethylene. Look for plastic in your yellow pages. You will probably find some place near you that sells scrap pieces for much less than grainger or McMaster-Carr.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    So what are people using this stuff for?
  9. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Between the leaves in a spring pack, per the 52 or 56 rebuild tech article.
    I bought mine at Tap ... they called it "high density" something-or-other. Cost me nine bucks for a roll almost as wide as the springs, IIRC.
    -- A
  10. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    For skid plates. I'm doing the entire underside and boat sides of my truck in it. I'm using 1/4" and bough from Mcmaster.
  11. dremu
    Feb 27, 2000
    15,968
    461
    :eek1: that can't be cheap ... but, umm, wow :bow:
    Doesn't it scratch, though, on rocks?
    -- A
  12. otisringle
    Aug 2, 2005
    148
    california
    yeah Im using it for my leaf springs, I looked in the phone book and found a place close to me but it was to expensive. $2.50 a foot.
    What thickness are you guys using?
  13. dremu
    Feb 27, 2000
    15,968
    461
    Wow! The stuff I bought was way thin, like duct or masking tape, and came on a roll, one side sticky, in fact.
    -- A
  14. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I used .030 material and its too thin. It has slowly worked its way out of the end of the springs. Another person (JEK ??) I believe used .060 material. I dont know how that has held up. I got mine from http://www.multicraftplastics.com/ in oregon. Bought it on a roll, 3" width and had to clean the adheasive off one side. Reasonable price. Called, told them what I wanted and they shipped it the next day.
  15. 1976Blazer76
    1976Blazer76 1/2 ton status
    Apr 17, 2006
    552
    Ridgefield, WA
    Oddly enough, I work at a plastics recycling place and my work deals with thousands and thousands of pounds of scraps of this material in all shapes and sizes. The stuff is tough, pretty hard on our machines that grinds it up and makes it back into powder.
  16. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    we use it on the bottom of our airboat...
  17. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Where (locally) do you get it?
  18. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    anywhere from 0.030" - 0.060" is fine. I have the thinner stuff on my rear 52s... and the thicker stuff on my front 52s... both work great. If you run it the entire length of the leaf and drill a center-pin-hole... it won't work its way out of the pack.
    UHMW-PE is much better than teflon... IMO it'd be more accurate to say that teflon is a "poor mans" UHMW. For a plastic, its impact resistance is crazy high... it can handle cryogenic temperatures without difficulty... it won't cold flow and its very slick. Its pretty much perfect for the spring or skid plate application. I am gonna have my K5s belly skid covered with UHMW... prolly have 1/8" steel with some beads rolled into it, covered be 3/8" or so UHMW. With enough force, you can scratch the stuff but its not like a scratch destroys the material or anything. A standard steel skid plate gets scratched too. No biggie.. and with UHMW the scratches won't result in rust. ;)
    j
  19. otisringle
    Aug 2, 2005
    148
    california
    how much is needed to do a set of 52's.
  20. 76Hillbilly
    76Hillbilly Registered Member
    Jun 29, 2006
    12
    arkansas
    for uhmw drop peices try http://www.rgausa.com/ or rubber and gasket company of america. they have a ton of drop peices. used to work there and the stuff is almost indestructable. comes in 1/32 to 1" thick. hope this helps
