ujoint conversion for a 6 lug 14 bolt SF
Discussion in 'The Garage' started by bajaviking, Nov 3, 2005.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    :confused: I am putting a 6 lug 14 bolt SF in my Blazer, what ujoints should I use? I currently have a 12 bolt in it.
    Thanks!
  2. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    14sf should be a 1350 joint. cant help ya on the part# tho.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You need the standard 1/2 -3/4 ton conversion joint. Do a search on this site and you should be able to find it. I don't know it off hand. Otherwise I'd tell you.
  4. bajaviking
    Apr 10, 2002
    752
    Baja
    Is is the same ujoint that you use for 14 bolt FF? If it is I think I have the partnumbers written down somewhere.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Hmm, when I swapped a 14 bolt SF into our '94 Suburban, the driveline shop guys told me that I could just swap the yoke from my old 10-bolt to the new 14. That way I didn't need a crossover joint. It worked. :cool1: But I'm not sure if the 12 bolt takes the same yoke or not. :confused:
  6. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    can i have more info on how you converted a 14 bolt to 6 lug?
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I didn't convert it. GM made a 6 lug version of the 14 bolt Single Floating axle. It was used in some extra cab 1/2-ton trucks and light-duty 3/4-tons. While not quite as beefy as a 14 bolt Full Floater, it is WAY beefier than a 10-bolt! :cool1: I just happened across one while trolling the aisles at the local pick-n-pull yard that matched the gear ratio of our '94 Sub.
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Harry, You're saying the S44 yoke fits the SF14B? The swap is just the yoke, correct? I needed a new u-joint anyway so I just bought the conversion one, but that's good info. I'm assuming your '94 'burb used the same rear as my '95 Yukon. My new rear was from an '88 light-duty 2500 (6 lug)
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I don't know what the part numbers and such are, but I was able to remove the yoke from my 10-bolt (1994) and install it directly in place of the yoke that was on the 14-bolt SF. :cool1:
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Give Jess a call at Highangledriveline. Really helpfull guy. :D
  11. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    1310-1350 is Neapco PN- 3-3140
    John
  12. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    The 3R yoke from a 10 bolt will fit the 14 bolt 9.5 sf. I did it on mine and it works great. You have to swap the seal guard hub thingy from the stock 1350 yoke to the 10 bolt 3R.
  13. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    So the pinion gear splines are the same on 10, 12 and 14sf axles?
    Won't putting the 12bolt yoke on the 14bsf require a different seal?
