Ujoint Questions
Discussion in 'The Garage' started by Hossbaby50, Dec 2, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Driveshaft ujoints are supposed to have the same amount of angle to not vibrate correct? (non CV)
    What is the max continuous angle for a 1350 ujoint?
    Harley
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Yes, the angles should be within 2° of each other. I would not go more than 15° on a DD if it was possible.
    You got vibes again??
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the only time the ujoint doest accel and decel is when perfectly straight
    how much angle until you can feel it ??
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Driveshaft at more angle will just wear out faster. As long as it doesn't bind, it will not break if it's 1 ton rated.
