ujoint upgrade questions
Discussion in 'The Garage' started by fatboy, Jan 25, 2004.
  1. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    pulling my trans(400)on my suburban and want to at least put stronger ujoints in frount and rear drive shafts. front axle is a 10 bolt and rear is a 14 bolt 4.10 gears. 36 inch tires and moderate wheeling. Havent had problems but I like to inprove everything on it that I pull off.
    Another qustion My front drive shaft has a lot of play in the slip yoke portion of it, the play is radial or side to side is that normal or is there a fix or do I need a new one?
    /forums/images/graemlins/ears.gif thanks guys and gals /forums/images/graemlins/burb.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You need a new slip yoke in your front driveshaft.
    What kind of transfer case does your rig have?
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Maybe well you've got the t-case out, you can take out the front axle and replace it with a 60 and put in a 1 ton dshaft.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Which you'd be disappointed to find that the 1 ton trucks use the same size u joints in their front driveshaft. /forums/images/graemlins/rolleyes.gif
  5. RustBuket
    Feb 21, 2003
    1,618
    Really?? Well thats shatty! Hahaha, guess I don't know much about 1 ton gear then. O well, you learn something new everyday. /forums/images/graemlins/cool.gif
  6. fatboy
    Jul 1, 2003
    290
    Tennesse
    transfer case is a 208. Is the one ton front shaft stronger? or is it just as well to replace the front slip yoke in my shaft (lol I wrote shaft) anyway thanks for the info /forums/images/graemlins/burb.gif
