ujoints - 1350 or 14whatever.. explain???
Discussion in 'The Garage' started by RootBreaker, May 12, 2006.
  1. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    Ok so to me I know nothing about ujoints other than going to the parts store and buy what the truck needs.
    I notice that people are saying they are upgrading to 1450 or whatever it is...
    so my 1978 has a cv up front... what size are they? what size is a front d60? and what size is a 14bolt ff?
    I have a spare front shaft that has a cv in it.... the splines are bad i believe.. I need a rear driveshaft and was thinking... couldnt I use the cv in the back and have a shaft made up to lessen the angle?
    my rear shaft angle is bad.. I have a 2 piece shaft... lowered the carrier bearing say 2-4" as my tranny and xfer case is dropped....but then that is 1/2 way back... then the shaft darts down to the axle.. due to that I have alot of wobbling if I hammer it hard... I can acutally get the rear wheels to hop, lay off of it then hammer it again :haha:
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    60=1310.........14boltff=1350
  3. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    With the 2 peice driveline you really need a c/v in the middle of that shaft if its lifted- as for joint size- if your running a 35 or larger go with a 1350 if possible and over a 38 go with 1410 when ever possible- or give me a call and i'll explain- here's a pic of the 2 piece with a c/v - Jess
  4. drivelineman
    Aug 23, 2000
    707
    that's a stock 2 piece - here's the custom c/v - Jess
  5. drivelineman
    Aug 23, 2000
    707
    and a pic of the different sizes of joints as refrence-
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    what is the biggest joint in that pic? 3rd and 4th joints from the left look like 1350 and 1410 respectively....
    btw, I noticed with the new flange/yokes that you guys offer for the ff14b that you can run 1480 joints. Thats just a D60 joint right? Does that mean you could run a CTM in there? lol! :grin: :thumb:
    j
  7. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    :thinking: I like the way you think, mister. :D I better just stick with my 1410 yokes though.
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    heh heh, I ain't rich enough to run CTMs in my axle shafts, let alone driveshafts... just thinking. :thumb: Wear shouldn't be a big problem, driveshaft turns a lot less than a axle shaft.. and without the ring/pinion gear reduction, I can't imagine any engine breaking that joint.
    j
