...UJoints...
Discussion in 'The Garage' started by Drey, May 18, 2004.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    All I ever hear is that weak 6.2 cant do anything worthwhile, it doesnt have any power. Well i murdered a Ujoint so it must have some I guess /forums/images/graemlins/thinking.gif
    Are there any certain brands you guys would recomend?
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I recommend buying a membership, someone like me may send you a free U Joint..........
  3. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Im telling and RJ just as soon as I get a good credit card offer in the mail, Ill sign up to be a member, I also wanna get a CK5 Shirt and some decals so dont thing Im to cheap to be a member.
    Btw...I didnt know they still had Post Offices out in Podunk, South Dakota. /forums/images/graemlins/rotfl.gif Just Kiddin Man
  4. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I live 5 miles west of Podunk thank you!
    Don't be CHEAP! (Like the budgie)
  5. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    [/ QUOTE ] If you take care of them they don't get weak as easy. I think pre existing damage due to poor care caused your ego boost. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  6. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    spicer forged cross joints are the best you get short of CTM type joints.
  7. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    How often should I grease and how do I tell when I have put enough grease in them?
  8. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I broke one with a 305..... I was trying to do a burnout and my brakes are biased very much to the rear (as I found out). The brakes lock up so tight in the rear that the u joint just let go before the tires spun.
  9. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    Install the non-greasable Spicer forged u-joints. They have bronze bushings instead of needle bearings.Whatever you do, don't try adding more grease in the caps, they are ready to go out of the box. They're in my front end, no worries. /forums/images/graemlins/smile.gif
  10. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    where can you get spicer joints???
  11. mtn. burb
    May 13, 2004
    1,260
    Ojai Calif.
    I got mine from Stephan at ORD. At the time he had them in stock. Call him regarding your axle. I'm sure plenty of places carry them. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Grease whenever you grease everything else, and grease until it purges from all four bearing caps. If one of the caps will not purge this means you have a problem.
    I do not use greasable joints though personally but that debate is endless.
    I've got a pair of 5-806x spicers for my D60 and they certainly have needle bearings. This is the best joint spicer makes for this application and it certainly doesn't have bronze sleeves.
  13. mtn. burb
    May 13, 2004
    1,260
    Ojai Calif.
    /forums/images/graemlins/doah.gif Yes, thats what I have. I know, I'll tell you my boy's were distracting me... /forums/images/graemlins/doah.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's cool. I haven't got mine installed yet...so many damn projects, I'll probably have my 35 spline outers before I go to install my new u joints.
