umm how do i get the caliper off a d60?
Discussion in 'The Garage' started by stoney126, Dec 3, 2005.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    A bit embarassed to ask but i need to change the pads on the my truck. 89 crewcab w/d60 disc's. I can tfigure out how to get the calipers off. Dont laugh to much :D
  2. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Look on the back bottom portion of the caliper
    Remove bolt
    Slide clip out and spring out
    Remove caliper
    When you re-install start spring and then slide clip and spring in together
    Russ
  3. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    cool i removed the bolt cut i wasnt sure if that was right. Thanks russ, info is very much appreciated.
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Very good pics and good explanation, but keep in mind that depending upon the condition of the 60, the clip may not "slide" out. I had to use a BFH and a large chisle to get the clip to move.
  5. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    ya mine didnt slide out, but i just gave em a tap with a screwdriver and out they came.
    Im having one hell of a time getting they spring and clip back in. I dont know why i cant get it to fit. I cant even get it to line up.
  6. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    also look it over good the clips can and do go bad and crack in 2 .
  7. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    ya the clips look good, gave them and the spring and the nothch that retains them a good cleaning. bout to blow to hell if i cant get the spring back in :D
  8. sweetk30
    Nov 1, 2004
    25,538
    538
    spring rides on top of clip at same time as reinstall.
  9. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    i can t seem to even get it to lead in at all, dont know what im doing wrong. Taking a lil break as im about to start kicking in the fenders if i continue :D
    Geez changing pads 20 seconds everything else, I tell you when i know.
  10. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    At least you got the bolt out....Mine are really stuck in there....
    Suggestions for that?
    Sorry about the Hi-Jack :eek1: :D
  11. sweetk30
    Nov 1, 2004
    25,538
    538
    heat bolt up with tourch till red and then cool off with cold water. this will shock it loose. sometimes need to do this 2-3 times. works great for bleader screws also.
  12. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    the allen head was stripped on mine, so i busted out the vice grips :D. goona pick up another toomorow.
  13. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Have you tried soaking it in PB blaster?
    now back on topic.
