unadjusted speedometer...problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Jun 18, 2001.
  1. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    I have an 85 Jimmy...350/700R4...with 4.56 gears and 35" BFGs....question...ever since I did all the lifting/gearing/bigger tires, my speedo has been off (naturally)...does this cause ANY problems other than not knowing how fast you are going?
    J
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Shouldn't. 85's should be non-comp controlled so it should be fine...
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    No problems...unless you really want to know how fast you are going?
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Your odometer will also be off. Now you won't be able to figure out your fuel mileage (I don't want to know mine).
    '71 Blazer CST with alot of rust
