Under-carriage wash??? So I can pinpoint leak.
Discussion in 'The Garage' started by 77Jimmy, Jul 21, 2003.
  1. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    I have a leak coming from somewhere on my tranny, but I really need to clean up the whole undercarriage so I can determine exactly where it’s coming from. Is there some sort of spray or wash or something that I can use to clean up the undercarriage with? I thought about just going to a local do it yourself car wash and using the power washer but I’m scared the cold water and hot engine, tranny and t-case wouldn’t like each other too much. /forums/images/graemlins/grin.gif Any thoughts?
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Find one that has hot water, they have them where I live, You could probable use a engine degreaser.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i do that to mine all the time and have never had a problem /forums/images/graemlins/thumb.gif
  4. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    yea , engine degreaser works great, i like pitt-pen better than that junkass GUNK spray. it's faster and you don't have to go over it ten times. my tb-400 leaks at the seal for the dip stick. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    See if You can find a pressure wash business in Your area. they have heated water, and around 2-3000 lbs. of pressure.
    And as the Other's have mentioned, Gunk engine bright or similar stuff will help alot. /forums/images/graemlins/grin.gif
  6. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Carb cleaner has been a good friend of mine for years. Buy a few cans and go to a self service car wash and get to work.
  7. 78GMCJIMMY
    78GMCJIMMY 1/2 ton status
    Mar 29, 2003
    135
    Gresham,Oregon
    Check your tranny cooler lines at the tranny.One of mine backed out this weekend and caused a BIG mess!Also check the modulator,pan,dipstick tube and around the front seal behind the inspection plate. Just a thought! /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/grin.gif
  8. 77Jimmy
    Sep 3, 2002
    661
    Atlanta, GA
    Found a nice self-service car wash last night w/ nice hot water. Took it mudding first /forums/images/graemlins/grin.gif, then hit the wash. Blasted it w/ hot soap and then warm water. Got it home and it looks like a leak coming from around the pan...going to check it out again tonight.
  9. 77Jimmy
    Sep 3, 2002
    661
    Atlanta, GA
    Thanks for the suggestions guys. Just an update...I think I found the leak...see my new post in the 2nd Gen forum. Thanks! /forums/images/graemlins/grin.gif
