Under Chassis Lighting
Discussion in 'The Garage' started by rockink5, Aug 7, 2003.
  1. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    I need to mount some rock lights under my truck for a trip next week /forums/images/graemlins/thumb.gif. Need suggestions on where to mount them so I don't rip them off with the a tire or on some rocks /forums/images/graemlins/eek.gif. Also what lights did you use? I think I am going to use some cheepy Walmart ricer specials, but I am open to suggestions. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I think some tractor lights would be better. Sealed, water proof, dust proof housing just seems better. Should be around $10 each. I think they come in either spot or flood pattern too. Might check with Tractor Supply or a local dealer. Just a thought.
    Kris
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    you can mount them on the inside of the frame pointing to the oppositte side and they'll be pretty well protected from damage..i have a set of blazer brand lamps that are as bright as daylighters im told and cost 9.99 at the bargain store
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    you gotta get purple /forums/images/graemlins/grin.gif
    wont they break when you bounce around alot?
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    This is the route I am thinking about going. I picked up a $4 trailer light at the Napa near my work. (industrial Napa) They are clear lights that are sealed and would be easy to mount. I haven't had a chance to wire one up and see how bright it is though.
    Harley
  6. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I was planning on doing this tomorrow. I'm going the tractor light route. 15 bucks here. Water proof and have a switch right on the light. Not sure why I would ever need that but its there. Not incredibly bright but then they aren't throwing light very far either. Look durable enough and you could probably afford to keep a spare one on hand. As far as mounting, haven't figured that out yet either. I was thinking find a hole in the frame and bolt them on. Haven't even looked yet but my wires are there and ready to go.
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'm thinking mounting in a hole next to the body mount would be best. I don't crawl but how often do you smack those?
  8. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    I got one fwd pointing light (55 watt Pro-Comp driving) on the front crossmember mounted at a 45* angle. One sealed trailer back-up lt mounted above my rear d-shaft. My back-up ligts are manually opperated and mounted on a swivel on my rear bumper so they can be left on and pointed down.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think the trick ones would be the 4" or so clear disposable plastic lights used on semis
    they are real fast to change when they die
    you can get blue/purple lenses like the guys use to illuminate the back of the cab/front of the trailer if you need the bling
    being cheap and disposable and easy to change is a good list of features for a rough envirnment, if you find you do not kill them constantly you could step up to LED version but they are 4 times the price
  10. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    mj, do they use the same bulb (inside the all that plastic) as the oval ones? That (oval style) is what I was talking about on the one over the d-shaft. I've got another spot I wanted to put the ovals, but no room. Just curious if I can expect the same light output.
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I do not know
    I would say yes
    the trick is to get one for a turn signal application and power both filaments for a really bright light
    you would be limited to amber or red though.
    the ovals is what was used for 'under the bumper poser' lights on my peterbilt
    I had a few guys asking what foglights I used on it, so they put out a fair light when both filaments are lit
    any truckstop in western US wanted $10-12 for the ovals so a parts house should be cheaper then that
    they are available everywhere so replacement in a pinch is real easy
    when I build my bumpers I will be using those lights to replace all of the factory lights on my chev
  12. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    Thanks, I thought I saw them in clear at the trailer place by the house. If not, amber will work for this set.
    [/ QUOTE ] I did something similar, but mounted them in the body, looks kind of like a '72 that way & no more broken tail lights.
  13. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    You may be able to get them in clear. Check here .
  14. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    Thanks, but I'n not doing LEDs on mine. Lots of local truck/tractor/trailor places.
  15. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Ended up mounting my lights in the holes left behind by the removed sway bar. Got a skid plate there to protect them. Worked pretty well. leaf springs block some of the light but not to bad. Now I have to sort out a major electrical mess.
  16. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    walmart cheapies.
    i got the rocer special (look for the ones in the orange box, lots of people using them.
    easy to wire, i put one in front of each tire pointed out at an angle.
    ~$30 for everything. i wired a relay in, so that cost a bit more, and its soo bright, i've worked on my rig at night with just the lights on.
  17. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    walmart cheapies.
    Those are the ones /forums/images/graemlins/thumb.gif Got them mounted with each set on its own relay, in case I want to add lights later on. They work great. Almost sounds as if I put them in the same place as you did.
  18. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    anybody got any pictures of how they mounted theres. im having trouble picturing it.
